Base_1.stl
Base design number 1. It integrates horizontal holes for the screwed quick 6mm (Outer Diameter) plugs and 3d printed internal guidance for water distribution. It's the red design in the pictures.
Standard Tesselated Geometry - 4.14 MB - 07/28/2024 at 15:28
Download
Base_2.stl
Base design number 2. It integrates vertical holes for the screwed quick 6mm (Outer Diameter) plugs. No integrated water distribution.
Standard Tesselated Geometry - 811.18 kB - 07/28/2024 at 15:28
Download
Base_3.stl
Base design number 3. It integrates vertical holes for the screwed quick 6mm (Outer Diameter) plugs. No integrated water distribution. The flushing system can be added with a 6mm flexible pipe. It's the green design in the pictures.
Standard Tesselated Geometry - 924.50 kB - 07/28/2024 at 15:28
Download
Hanger.stl
Hanging part for the rear
Standard Tesselated Geometry - 105.87 kB - 07/28/2024 at 15:28
Download
Top.stl
Upper cover to protect the electronics
Standard Tesselated Geometry - 221.28 kB - 07/28/2024 at 15:28
Download
