The final version of the counter is on the image below. With the size of the PCB and components (most of 0805) this is the best layout for the two layers board
The power wiring is far from the perfect but acceptable for this case
A project log for Renovation of the E004 audio tape recorder
A low-cost, high-quality tape recorder with a cross-board architecture.
