plate _actually_ en route (hopefully)
A project log for The Circuit Graver
Carve PCBs at home using a machine you build!
zakqwyzakqwy • 09/05/2024 at 12:16•0 Comments
Read the specs! My plate got rejected because the holes were too close to the edge and violated some DFM rules from the fabricator:
Then it got rejected again because the _tapped_ holes were too close still:
For the second round, a helpful customer service rep sent a picture with minimum clearances around each hole, which highlighted the eight offending taps (and eight taps that were within spec, since the yellow circle stayed within the outline):
Dang, they were patient with me. With any luck the latest iteration goes through; I moved a few taps in a bit where I could, and changed the servo mounts to non-tapped slots. Hooray for helpful vendors. I'm so used to checking design rules for PCB vendors; maybe I didn't think about it much here because I'm used to bending the waterjet cutter to my will and probably making non-conforming parts in the process. Slow down, do engineering, etc.
