1Program the Pi 4
The recommended stable OS for this build is Ubuntu 24.04 for Raspberry Pi.
https://cdimage.ubuntu.com/releases/24.04/release/
Download Pi flasher to flash an SD card with the image.
https://www.raspberrypi.com/software/
Then plug in that SD card and flash that Pi
2Mount motor hat
The SunFounder motor hat is what we use for this build
https://www.sunfounder.com/products/sunfounder-robot-hat-expansion-board-designed-for-raspberry-pi
https://www.amazon.com/SunFounder-Expansion-Raspberry-Inclulded-Rechargeable/dp/B0CKTD7QJB
I would not use the bottom mount points and use smaller ones so something like this would work with the M.2 screws that come with the SunFounder Pi Hat
https://www.amazon.com/AVERZELLA-M-2-SSD-Screw-kit/dp/B091B76RRC
3Print and lay out 3D printed parts
For the main body, undercarriage, wheels and horns:
https://www.printables.com/model/964421-tengu-marauder-frame
I ended up using these for my caster and wheels, reccomend you print in TPU for the wheels
4Create and mount wheels on TT motors
Cover the TPU tire over the wheel and mount it on the TT motor
5Mount the TT motor on the undercarriage
Take the motors and put on the undercarriage make sure to screw in the motors to the mounts. Use self tapping screws
6Flash the ESP32 with Marauder
Using a flashing software such as Arduino, PlatformIO or such as this https://github.com/SkeletonMan03/FZEasyMarauderFlash
You will hold the reset button on the ESP32 board for 5 seconds and plug in the usb cord until a COM port comes up in either device manager (if windows) or dmesg (linux
7Flash the Raspberry Pi with Ubuntu
Lexi
