Open-source repository:
11/10/2024 at 02:51 • 0 commentsHardware:https://oshwhub.com/wlmh110/esp32-i2s-tf
Software:https://github.com/wlmh110/ESP32test
The hardware cost is approximately $6 (excluding battery and processing fees). Key components include an ESP-32 ($2.5) and an INMP1441 ($1.5).
Hardware verification for the proposed solution has been completed
11/09/2024 at 04:03 • 0 commentsHardware verification for the proposed solution has been completed. The ESP32-based hardware used for verification has been validated. This verification board can record audio upon button press and stop recording upon release. The recorded data is then sent to a TCP server.
This verification board can now serve as a basic trigger-based voice assistant, although it is still far from our ultimate goal. Attached are photos of the verified hardware solution. The open-source link for the entire project design will be updated shortly, including hardware design, preliminary verification code, and a simple test server code (which merely packages the received audio data into a WAV file).
SMT is completed
08/26/2024 at 03:42 • 0 commentsSMT is completed, and next we will test the function of the recording part.
The customized PCB has arrived and will be sent to the factory for welding
08/15/2024 at 04:15 • 0 comments -
Preliminarily complete the hardware design of the ESP32 solution
08/10/2024 at 09:32 • 0 commentsThe design uses the ESP32-WROVER primarily because of its large memory capacity.
The MIC is an INMP441, and data is directly obtained via I2S.
There is a button for user operation and an RGB LED to indicate status.
There is a TF card slot, which is not part of the original functionality because the TF card consumes a lot of power; it is included only for debugging audio data.
The battery uses a PH2.0 connector to facilitate the use of different solutions.
The PCB has a diameter of 4 cm and includes a slot for the ESP32 antenna.
The current hardware cost of the solution is approximately $6 (excluding the battery).
Since the PCB has not been verified yet, a public link for the schematic diagram generation has not been created. After the verification is completed, the schematic diagram and PCB address will be filled in the project.
