PCB Version 1.7 - Current project state
A project log for Clockception
Another "A million times clock"-clock-build
fabianFabian 08/05/2024 at 21:100 Comments
Below you can see some details of the current PCB version.
On the front side of the PCB you can see the landing pads for the SK6812 LEDs and the HC49 hall sensors. I used white silk screen around the led ring to increase the light reflection in that area.
With this iteration I also introduced a pogo pin based flashing connector. This way it should be easier to flash a high amount of PCBs and save components.
