Custom PCBs from PCB Way - (Get $5 New User Credit)
Bill of materials
- Add-on pcb → BOM
- Waveshare 4inch screen Amazon
- Raspberry Pi 4 Amazon
- Micro SD card Amazon
- 15W USB-C Power Supply Amazon
- Heatsink with PWM Controllable Fan Amazon
- Hook-up wire Amazon
- Dupont Connectors Amazon
- JST-PH Compatible Connector Amazon
- M2 Self-Tapping Screws Assortment Amazon
- Rubber Feet Amazon
- HDMI cable Adafruit - Aliexpress
- 1 × Micro HDMI Plug Right Angle (R Bend)
- 1 × Standard HDMI Plug Right Angle (R bend)
- 1 × HDMI FFC cable (20cm)
- Acrylic Primer Amazon
- Airbrush Paint
- GOLDEN High Flow Titan Buff Amazon
- GOLDEN High Flow Transparent Shading Gray Amazon
- GOLDEN High Flow Neutral Gray 5
- Acrylic White
- Airbrush Thiner
Tools
- Resin Printing System Heygears
- Soldering Station/Iron. Amazon
- Helping hands Amazon
- Precision Screwdriver Set Amazon
- Airbrush Amazon
- Wire stripper Amazon
- Sanding Sponges Amazon
- Crimping tools Amazon
- Heat shrink tubing Amazon
- Flux, Solder, Solder paste
- Sandpaper Assortment
- Flush cutters
- Tweezers, pliers
- Hot glue
Affiliate links may be included in this list. I may receive a small commission at no additional cost to you.
Salim Benbouziyane
William
shin
Daniel Frausto
