Pressing the charge check button on the front of the unit starts everything off.
You are first greeted with the following data (time stamps are from CuteCom). The data is comma separated.
[18:30:51:778] <0xff>000006591,WKUP 2␍␊ [18:30:51:826] 000006638,v2.4.2,2020.10.7,4868da2e,5,2␍␊ [18:30:51:830] 000006639,st 4␍␊ [18:30:51:833] 000006643,defects:00000001␍␊ [18:30:52:193] 000007000,R40G4.2,04,00028800,00,00,1,1,1,1, -8,35867,3624,3626,3624,3626,3623,3244,3623,3627,3626,3624, 250, 248, 0, 0, 0, 0, 0,0000,0000␍␊ [18:30:52:693] 000007500,R40G4.2,04,00028800,00,00,0,0,0,0, 0,35866,3624,3626,3624,3626,3623,3244,3623,3626,3626,3624, 250, 248, 0, 0, 0, 0, 0,0000,0000␍␊ [18:30:53:193] 000008000,R40G4.2,04,00028800,00,00,1,1,1,1, 0,35866,3624,3626,3624,3626,3623,3244,3623,3626,3626,3624, 250, 248, 0, 0, 0, 0, 0,0000,0000␍␊ [18:30:53:693] 000008500,R40G4.2,04,00028800,00,00,0,0,0,0, 0,35867,3624,3626,3624,3626,3623,3244,3623,3627,3626,3624, 250, 248, 0, 0, 0, 0, 0,0000,0000␍␊ [18:30:54:193] 000009000,R40G4.2,04,00028800,00,00,1,1,1,1, -8,35866,3624,3626,3624,3626,3623,3244,3623,3626,3626,3624, 250, 248, 0, 0, 0, 0, 0,0000,0000␍␊ [18:30:54:694] 000009500,R40G4.2,04,00028800,00,00,0,0,0,0, 8,35866,3624,3626,3624,3626,3623,3244,3623,3626,3626,3624, 250, 248, 0, 0, 0, 0, 0,0000,0000␍␊ [18:30:55:194] 000010000,R40G4.2,04,00028800,00,00,1,1,1,1, 0,35865,3624,3626,3623,3626,3623,3244,3623,3626,3626,3624, 250, 248, 0, 0, 0, 0, 0,0000,0000␍␊ [18:30:55:694] 000010500,R40G4.2,04,00028800,00,00,0,0,0,0, -8,35866,3624,3626,3624,3626,3623,3244,3623,3626,3626,3624, 250, 248, 0, 0, 0, 0, 0,0000,0000␍␊ [18:30:56:194] 000011000,R40G4.2,04,00028800,00,00,1,1,1,1, 0,35866,3624,3626,3624,3626,3623,3244,3623,3626,3626,3624, 250, 248, 0, 0, 0, 0, 0,0000,0000␍␊ [18:30:56:694] 000011500,R40G4.2,04,00028800,00,00,0,0,0,0, -8,35867,3624,3626,3624,3626,3623,3244,3623,3627,3626,3624, 250, 248, 0, 0, 0, 0, 0,0000,0000␍␊ [18:30:57:195] 000012000,R40G4.2,04,00028800,00,00,1,1,1,1, -8,35865,3624,3626,3623,3626,3623,3244,3623,3626,3626,3624, 250, 248, 0, 0, 0, 0, 0,0000,0000␍␊ [18:30:57:695] 000012500,R40G4.2,04,00028800,00,00,0,0,0,0, 0,35866,3624,3626,3624,3626,3623,3244,3623,3626,3626,3624, 250, 248, 0, 0, 0, 0, 0,0000,0000␍␊ [18:30:57:828] 000012638,st 1␍␊ [18:30:58:195] 000013000,R40G4.2,01,00028800,00,00,0,0,0,0, 0,35867,3624,3626,3624,3626,3623,3244,3623,3627,3626,3624, 250, 248, 0, 0, 0, 0, 0,0000,0000␍␊ [18:30:58:695] 000013500,R40G4.2,01,00028800,00,00,0,0,0,0, 0,35868,3624,3626,3624,3626,3623,3244,3624,3627,3626,3624, 250, 248, 0, 0, 0, 0, 0,0000,0000␍␊
The first 4 rows appear to be header data giving the status of free running clock, greeting, version info, date of manufacture? and serial number?
You can also hold the battery charge button until it lights up solid and the unit will continually report data until you short RST to GND.
Shorting RST to GND will produce the following ouput
What I find interesting is the spaces in some of the fields. This also appears notable.
defects:00000001 |
