The battery started giving me the LED blinks of death. Online searching said "easy fix". So far the fixes didn't work. I did however find several header pins which proved interesting. I soldered on the header and button.
There are 2 main headers. One has CLK an DIO that looks interesting
The other has ISP, TX, RX. The serial port runs at 115200, N, 8, 1
Main IC is NXP LCP82X (824J)
LPC82x
32-bit ARM® Cortex ®-M0+ microcontroller; up to 32 kB flash
and 8 kB SRAM; 12-bit ADC; comparator
Second IC (U6) is Q7693003 6 to 10-Series Cell Li-Ion and Li-Phosphate Battery Monitor (bq76940 Family)
Project logs provide further details.
Been trying to convert the I2C data (U6) into human readable format but getting stuck on how the read data is formatted. There's a post in the project log about it. I'd like some help. The writes look good.
Don
Tinkers Projects
Shrinath Nimare
Is it saying cell 6 is knackered? The voltage looks lower than the others too.
LED blinks 6 times too :-)
