Oopsy
12/06/2024 at 22:54 • 0 commentsI was cleaning up things in the basement and accidentally shorted the data line for the BMS chip to the battery lead. Magic smoke has escaped.
Math is hard
08/14/2024 at 15:50 • 0 commentsV(cell) = GAIN x ADC(cell) + OFFSET So
I2C
08/11/2024 at 15:41 • 2 commentsSoldered on to the SDA and SCL pins of U6. File uploaded.
I uploaded the raw data files and I'm having trouble converting the values. See the i2c data.ods (libreoffice calc document). I've split out the commands and data returned. However, I'm not familar with the nomenclature used in the Datasheet with regards to '2'complement' and 'atomic value'.
BQ76930 6 to 10-Series Cell Li-Ion and Li-Phosphate Battery Monitor
08/11/2024 at 14:21 • 0 commentsThis is the U6 on the board. This looks more promising from my expertise and tool set. TI has quite of bit of documentation and guides on this chip. I'll investigate this and see what kind of information it provides to the micro controller.
AKA
AFE (Analog Front End)
32-bit ARM® Cortex ®-M0+ microcontroller
08/11/2024 at 14:17 • 0 commentsThis is U1 on the circuit board. I don't have the tools necessary to further investigate this chip. I would assume it may be possible to de-solder this chip and dump it's contents. -
LED Patterns and data file
08/11/2024 at 14:15 • 0 commentsShort press of voltage check button
LED 1-4 blink 6 times
Long press of voltage check button
LED 1-4 on for ~2 seconds
LED 1,2 blink 1 times
LED 1 blink 6 times
My assumption of what I thought was a binary pattern in the data is wrong. This is state of the four LEDs on battery.
Votlages
08/11/2024 at 13:52 • 0 commentsThere are 4 distinct sizes of test pads. I'll call them tiny, small, medium, large
The large pads appear to relate to the battery cells
The medium pads appear to be internal voltage test points
The small pads I'm not sure yet
The tiny pads I'm not sure yet
TP18 changes from 0 to 5VDC when in test mode
Each cell has a S# pad that removes the cell from the circuit. This causes a
001734242,AFE voltage invalid␍
AFE = Analog Front End = U6 = QB7693003
message to be displayed on the serial output.
Serial Data partially decoded
08/08/2024 at 23:02 • 0 commentsPressing the charge check button on the front of the unit starts everything off.
You are first greeted with the following data (time stamps are from CuteCom). The data is comma separated.
[18:30:51:778] <0xff>000006591,WKUP 2␍␊ [18:30:51:826] 000006638,v2.4.2,2020.10.7,4868da2e,5,2␍␊ [18:30:51:830] 000006639,st 4␍␊ [18:30:51:833] 000006643,defects:00000001␍␊ [18:30:52:193] 000007000,R40G4.2,04,00028800,00,00,1,1,1,1, -8,35867,3624,3626,3624,3626,3623,3244,3623,3627,3626,3624, 250, 248, 0, 0, 0, 0, 0,0000,0000␍␊ [18:30:52:693] 000007500,R40G4.2,04,00028800,00,00,0,0,0,0, 0,35866,3624,3626,3624,3626,3623,3244,3623,3626,3626,3624, 250, 248, 0, 0, 0, 0, 0,0000,0000␍␊ [18:30:53:193] 000008000,R40G4.2,04,00028800,00,00,1,1,1,1, 0,35866,3624,3626,3624,3626,3623,3244,3623,3626,3626,3624, 250, 248, 0, 0, 0, 0, 0,0000,0000␍␊ [18:30:53:693] 000008500,R40G4.2,04,00028800,00,00,0,0,0,0, 0,35867,3624,3626,3624,3626,3623,3244,3623,3627,3626,3624, 250, 248, 0, 0, 0, 0, 0,0000,0000␍␊ [18:30:54:193] 000009000,R40G4.2,04,00028800,00,00,1,1,1,1, -8,35866,3624,3626,3624,3626,3623,3244,3623,3626,3626,3624, 250, 248, 0, 0, 0, 0, 0,0000,0000␍␊ [18:30:54:694] 000009500,R40G4.2,04,00028800,00,00,0,0,0,0, 8,35866,3624,3626,3624,3626,3623,3244,3623,3626,3626,3624, 250, 248, 0, 0, 0, 0, 0,0000,0000␍␊ [18:30:55:194] 000010000,R40G4.2,04,00028800,00,00,1,1,1,1, 0,35865,3624,3626,3623,3626,3623,3244,3623,3626,3626,3624, 250, 248, 0, 0, 0, 0, 0,0000,0000␍␊ [18:30:55:694] 000010500,R40G4.2,04,00028800,00,00,0,0,0,0, -8,35866,3624,3626,3624,3626,3623,3244,3623,3626,3626,3624, 250, 248, 0, 0, 0, 0, 0,0000,0000␍␊ [18:30:56:194] 000011000,R40G4.2,04,00028800,00,00,1,1,1,1, 0,35866,3624,3626,3624,3626,3623,3244,3623,3626,3626,3624, 250, 248, 0, 0, 0, 0, 0,0000,0000␍␊ [18:30:56:694] 000011500,R40G4.2,04,00028800,00,00,0,0,0,0, -8,35867,3624,3626,3624,3626,3623,3244,3623,3627,3626,3624, 250, 248, 0, 0, 0, 0, 0,0000,0000␍␊ [18:30:57:195] 000012000,R40G4.2,04,00028800,00,00,1,1,1,1, -8,35865,3624,3626,3623,3626,3623,3244,3623,3626,3626,3624, 250, 248, 0, 0, 0, 0, 0,0000,0000␍␊ [18:30:57:695] 000012500,R40G4.2,04,00028800,00,00,0,0,0,0, 0,35866,3624,3626,3624,3626,3623,3244,3623,3626,3626,3624, 250, 248, 0, 0, 0, 0, 0,0000,0000␍␊ [18:30:57:828] 000012638,st 1␍␊ [18:30:58:195] 000013000,R40G4.2,01,00028800,00,00,0,0,0,0, 0,35867,3624,3626,3624,3626,3623,3244,3623,3627,3626,3624, 250, 248, 0, 0, 0, 0, 0,0000,0000␍␊ [18:30:58:695] 000013500,R40G4.2,01,00028800,00,00,0,0,0,0, 0,35868,3624,3626,3624,3626,3623,3244,3624,3627,3626,3624, 250, 248, 0, 0, 0, 0, 0,0000,0000␍␊
The first 4 rows appear to be header data giving the status of free running clock, greeting, version info, date of manufacture? and serial number?
You can also hold the battery charge button until it lights up solid and the unit will continually report data until you short RST to GND.
Shorting RST to GND will produce the following ouput
What I find interesting is the spaces in some of the fields. This also appears notable.defects:00000001
