Ryobi 40V Battery investigations
Exploring the innards of the battery
donDon
Battery is reporting an error so why not open it up to figure out a way to fix it.
The battery started giving me the LED blinks of death. Online searching said "easy fix". So far the fixes didn't work. I did however find several header pins which proved interesting. I soldered on the header and button.
There are 2 main headers. One has CLK an DIO that looks interesting
The other has ISP, TX, RX.  The serial port runs at 115200, N, 8, 1
Main IC is NXP LCP82X (824J)
LPC82x
32-bit ARM® Cortex ®-M0+ microcontroller; up to 32 kB flash
and 8 kB SRAM; 12-bit ADC; comparator
Second IC (U6)  is Q7693003 6 to 10-Series Cell Li-Ion and Li-Phosphate Battery Monitor (bq76940 Family)
Project logs provide further details.
Been trying to convert the I2C data (U6) into human readable format but getting stuck on how the read data is formatted. There's a post in the project log about it. I'd like some help. The writes look good.
i2c Data.ods
spreadsheet - 916.75 kB - 08/12/2024 at 21:43
Download
i2C.txt
Saved as Hex
plain - 305.76 kB - 08/12/2024 at 21:36
Download
i2c binary.txt
Saved as binary
plain - 451.81 kB - 08/12/2024 at 21:35
Download
Battery I2C.sal
Data Capture of I2C
sal - 5.51 MB - 08/11/2024 at 15:41
Download
cutecom_mildly_formatted.xlsx
converted to spreadsheet
sheet - 116.82 kB - 08/08/2024 at 22:21
Download
View all 6 files
  • Oopsy
    Don12/06/2024 at 22:54 0 comments
    was cleaning up things in the basement and accidentally shorted the data line for the BMS chip to the battery lead. Magic smoke has escaped.
  • Math is hard
    Don08/14/2024 at 15:50 0 comments
    V(cell) = GAIN x ADC(cell) + OFFSET
    So
  • I2C
    Don08/11/2024 at 15:41 2 comments
    Soldered on to the SDA and SCL pins of U6. File uploaded.
    I uploaded the raw data files and I'm having trouble converting the values. See the i2c data.ods (libreoffice calc document). I've split out the commands and data returned. However, I'm not familar with the nomenclature used in the Datasheet with regards to '2'complement' and 'atomic value'.
  • BQ76930 6 to 10-Series Cell Li-Ion and Li-Phosphate Battery Monitor
    Don08/11/2024 at 14:21 0 comments
    This is the U6 on the board. This looks more promising from my expertise and tool set. TI has quite of bit of documentation and guides on this chip. I'll investigate this and see what kind of information it provides to the micro controller.
    AKA
    AFE (Analog Front End)
  • 32-bit ARM® Cortex ®-M0+ microcontroller
    Don08/11/2024 at 14:17 0 comments
    This is U1 on the circuit board. I don't have the tools necessary to further investigate this chip. I would assume it may be possible to de-solder this chip and dump it's contents.
  • LED Patterns and data file
    Don08/11/2024 at 14:15 0 comments
    Short press of voltage check button
    LED 1-4 blink 6 times
    Long press of voltage check button
    LED 1-4 on for ~2 seconds
    LED 1,2 blink 1 times
    LED 1 blink 6 times
    My assumption of what  I thought was a binary pattern in the data is wrong. This is state of the four LEDs on battery.
  • Votlages
    Don08/11/2024 at 13:52 0 comments
    There are 4 distinct sizes of test pads. I'll call them tiny, small, medium, large
    The large pads appear to relate to the battery cells
    The medium pads appear to be internal voltage test points
    The small pads I'm not sure yet
    The tiny pads I'm not sure yet
    TP18 changes from 0 to 5VDC when in test mode
    Each cell has a S# pad that removes the cell from the circuit. This causes a
    001734242,AFE voltage invalid␍
    AFE = Analog Front End = U6 = QB7693003
    message to be displayed on the serial output.
  • Serial Data partially decoded
    Don08/08/2024 at 23:02 0 comments
    Pressing the charge check button on the front of the unit starts everything off.
    You are first greeted with the following data (time stamps are from CuteCom). The data is comma separated.
    [18:30:51:778] <0xff>000006591,WKUP 2␍␊
    [18:30:51:826] 000006638,v2.4.2,2020.10.7,4868da2e,5,2␍␊
    [18:30:51:830] 000006639,st 4␍␊
    [18:30:51:833] 000006643,defects:00000001␍␊
    [18:30:52:193] 000007000,R40G4.2,04,00028800,00,00,1,1,1,1,    -8,35867,3624,3626,3624,3626,3623,3244,3623,3627,3626,3624, 250, 248,     0, 0,     0,   0,   0,0000,0000␍␊
    [18:30:52:693] 000007500,R40G4.2,04,00028800,00,00,0,0,0,0,     0,35866,3624,3626,3624,3626,3623,3244,3623,3626,3626,3624, 250, 248,     0, 0,     0,   0,   0,0000,0000␍␊
    [18:30:53:193] 000008000,R40G4.2,04,00028800,00,00,1,1,1,1,     0,35866,3624,3626,3624,3626,3623,3244,3623,3626,3626,3624, 250, 248,     0, 0,     0,   0,   0,0000,0000␍␊
    [18:30:53:693] 000008500,R40G4.2,04,00028800,00,00,0,0,0,0,     0,35867,3624,3626,3624,3626,3623,3244,3623,3627,3626,3624, 250, 248,     0, 0,     0,   0,   0,0000,0000␍␊
    [18:30:54:193] 000009000,R40G4.2,04,00028800,00,00,1,1,1,1,    -8,35866,3624,3626,3624,3626,3623,3244,3623,3626,3626,3624, 250, 248,     0, 0,     0,   0,   0,0000,0000␍␊
    [18:30:54:694] 000009500,R40G4.2,04,00028800,00,00,0,0,0,0,     8,35866,3624,3626,3624,3626,3623,3244,3623,3626,3626,3624, 250, 248,     0, 0,     0,   0,   0,0000,0000␍␊
    [18:30:55:194] 000010000,R40G4.2,04,00028800,00,00,1,1,1,1,     0,35865,3624,3626,3623,3626,3623,3244,3623,3626,3626,3624, 250, 248,     0, 0,     0,   0,   0,0000,0000␍␊
    [18:30:55:694] 000010500,R40G4.2,04,00028800,00,00,0,0,0,0,    -8,35866,3624,3626,3624,3626,3623,3244,3623,3626,3626,3624, 250, 248,     0, 0,     0,   0,   0,0000,0000␍␊
    [18:30:56:194] 000011000,R40G4.2,04,00028800,00,00,1,1,1,1,     0,35866,3624,3626,3624,3626,3623,3244,3623,3626,3626,3624, 250, 248,     0, 0,     0,   0,   0,0000,0000␍␊
    [18:30:56:694] 000011500,R40G4.2,04,00028800,00,00,0,0,0,0,    -8,35867,3624,3626,3624,3626,3623,3244,3623,3627,3626,3624, 250, 248,     0, 0,     0,   0,   0,0000,0000␍␊
    [18:30:57:195] 000012000,R40G4.2,04,00028800,00,00,1,1,1,1,    -8,35865,3624,3626,3623,3626,3623,3244,3623,3626,3626,3624, 250, 248,     0, 0,     0,   0,   0,0000,0000␍␊
    [18:30:57:695] 000012500,R40G4.2,04,00028800,00,00,0,0,0,0,     0,35866,3624,3626,3624,3626,3623,3244,3623,3626,3626,3624, 250, 248,     0, 0,     0,   0,   0,0000,0000␍␊
    [18:30:57:828] 000012638,st 1␍␊
    [18:30:58:195] 000013000,R40G4.2,01,00028800,00,00,0,0,0,0,     0,35867,3624,3626,3624,3626,3623,3244,3623,3627,3626,3624, 250, 248,     0, 0,     0,   0,   0,0000,0000␍␊
    [18:30:58:695] 000013500,R40G4.2,01,00028800,00,00,0,0,0,0,     0,35868,3624,3626,3624,3626,3623,3244,3624,3627,3626,3624, 250, 248,     0, 0,     0,   0,   0,0000,0000␍␊
    The first 4 rows appear to be header data giving the status of  free running clock, greeting, version info, date of manufacture? and serial number?
    Serial Data
    You can also hold the battery charge button until it lights up solid and the unit will continually report data until you short RST to GND.
    Shorting RST to GND will produce the following ouput
    RST to GND
    What I find interesting is the spaces in some of the fields. This also appears notable.
    defects:00000001
View all 8 project logs
Adam Quantrill wrote 08/14/2024 at 15:31 point
Is it saying cell 6 is knackered? The voltage looks lower than the others too.
LED blinks 6 times too :-)
Gravis wrote 08/14/2024 at 13:22 point
I did some search-fu and found a forum post you may have overlooked. It states that "[i]t is possible to charge a 40V pack using a power supply by connecting a high value pull-up resistor between the + terminal and the T1". https://www.diyelectriccar.com/threads/ryobi-18v-lithium-battery-internals-and-charging.202243/#post-1104239
As for decoding the protocol, you might try to dump the firmware using a fault injection.
David Pye wrote 08/14/2024 at 09:15 point
https://github.com/davidmpye/V10_Dyson_BMS/wiki/Hardware-info
I did a new firmware for the Dyson v10 packs which uses a BMS IC from the same family.
The code I wrote might help you understand how to interpret the values.
Cheers
David
Don wrote 08/14/2024 at 12:09 point
I'll take a look. Thank you.
Don wrote 08/14/2024 at 15:48 point
See project log "math is hard" . I think I'm doing something wrong with assuming 16 bits for data.
crjeder wrote 08/14/2024 at 06:45 point
jonfoster wrote 08/14/2024 at 12:31 point
@crjeder That Wikipedia page is impossible for most programmers to understand.  It's hard enough for me to understand, and I have a math degree!
Two's complement is actually really easy for programmers, once you know the tricks.
I've posted a long comment on the "I2C" log, which has an explanation of two's complement aimed at programmers.
Dan Maloney wrote 08/13/2024 at 15:54 point
Very cool, love these reverse engineering heroics. Wrote this up for the blog, should post soon. Thanks for the tip!
