Step 1: Full Video Instructions On How To Do It
Take a look at the video above for a quick look at how to make a Magnetic Levitation Snail Lamp
Step 2: Detailed Main Board
Here is the main circuit diagram of the Magnetic Levitation Base.
It uses magnetic effects (resonance, magnetic energy compensation) to balance and levitate an object with a magnet.
The circuit diagram, PCB layout (Designed on Altium software), and component list are attached in the link below.
Source Magnetic Levitation Base
Step 3: Magnetic Field Sensor
This is the magnetic field sensor,
which helps balance the system based on the magnetic field values.
The detailed soldering method for the sensor is described as shown in the image above.
Step 4: Install Inductor
This is the position and soldering method for the coils providing the magnetic field for the main circuit.
Step 5: Attach Special Components to the Main Board
Here is an image of the main board after the electronic components have been assembled and soldered onto the PCB.
You can also see the silver screw from the back into the iron sheet.
fixing the inductor on the circuit board.
A metal iron sheet has been attached to help secure the round magnet of the board.
we will attach the round magnet to the metal sheet on the main board.
This magnet provides the primary magnetic force, which, combined with the automatically adjusted magnetic forces from the four coils, helps balance our Magnetic Levitation Base system.
Step 6: Wireless Power Supply Circuit
Next is the wireless power supply circuit.
I have also attached the complete circuit diagram, PCB layout (Designed on Altium software), and component list are attached in the link below.
Step 7: Module Led
This is the LED module used, which is a 16-color module controlled remotely via a remote control with a rechargeable battery.
Additionally, you can choose different types of LED modules, as they come in a wide variety of qualities, designs, and colors, like some of the modules I have here.
Remember to choose an LED module with a built-in rechargeable battery.
Step 8: 3D Printing Snail Lamp
I have also provided you with the design file of the snail lamp so you can 3D print it.
Based on the file I sent, you can also customize the shape, size, and choose to print it in your favorite color.
Actual image of the snail lamp model after 3D printing.
Here are some beautiful color combinations for the snail lamp that you can refer to.
Step 9: Solder the Coil Wireless Power Supply
Solder the coil to the receiving board of the wireless power supply.
Solder the coil to the transmitting board of the wireless power supply.
Step 10: Secure the Coil to the Main Board
Next, you need to solder the wireless power supply transmitter board and secure the coil to the main board as shown in the image above.
Additionally, you should use a power switch for the transmitter board to enable you to control the charging mode for the Snail Lamp.
Step 11: Testing the Wireless Power Supply
I am testing the wireless power supply transmitter board's ability to provide remote power.
A small note for you: the charging distance, whether near or far, depends on the type of coil you choose for the transmitter/receiver wireless power supply circuit.
In other words, the inductance value of the coil affects the distance at which the circuit can supply voltage.
Step 12: Attach Led Module and Components to Snail Lamp
Attach the magnet to the base plate of the snail lamp with glue.
You can see in the Image that I have attached the receiving board of the wireless power supply module and the led module to the inside of the snail lamp and they are attached with glue.
An important note is the receiver coil of the wireless power supply circuit should not be placed directly...
mrdiytechmagic
Silícios Lab
DIY GUY Chris
haas
Arnov Sharma
