Features:
- Offline Maps & GPS: Navigate with confidence using USGS topo maps and hardware GPS, all without an internet connection.
- Custom File Server: Upload your own trail essentials—knot guides, plant IDs, audiobooks, you name it—and access them anytime.
- Portable & USB-Powered: Small enough to toss in your pack, and powered by a simple USB-A connection, so you can keep going as long as your battery lasts.
- Easy Connection: Hosts a Wi-Fi access point with a QR code, making it easy to connect and access your maps and files.
Limitations:
- Speed Limits: With server I/O capped at around 1MBPS, you might need to pack a little patience along with your gear. This device isn’t winning any speed races.
- No Concurrency Champs Here: While multiple connections are fine, don’t expect it to juggle multiple file requests at once. One at a time, please— besides, whats your rush out here?
- DIY File Loading: You’ll need to load your own files and topo maps onto the device, so make sure you’re prepped before hitting the trail
Brett Smith
rmolines
lpauly
While larger, the BZ-251 has an onboard QMC5883 compass. Are there enough free cycles in the loop to read the value and display a heading instead of the qr code when a device is connected?
