1Before you Start:
PRINT GUIDE:
(A) = Accent Color
xN = Number of items necessary
(S) = Structural;
For structural parts:
- 4 or more Walls
- 6 or more Bottom Layers
- 6 or more Top Layers
- 20% or more Infill
- Gyroid, Cubic, 3D HoneyComb and Cross-Hatch are preferred, but you can use whatever you want.
Make sure you have all the tools listed below at your disposal. Optional tools are listed marked with an (o)
Pliers: For tightening m3 nuts
Allen Keys: If you're working with button head screws, you'll need a 2mm Allen key. If you''re working with Socket Head Screws, you will need a 2,5mm Allen Key.
Tiny Philips or Socket ScrewDriver: for tightening the terminal block screws, also, if you're using pan head screws for your build, you'll probably need some bigger ones as well.
Soldering Iron = for... soldering stuff, obviously
(o)Crimp Tool and 2.8mm Crimping Terminals = I would highly recommend these, but its not strictly necessary to complete the build.
(o)Silicone HeatShrink sleeves = Again, not strictly necessary, but I recommend it.
2Step 2
