Introduction
Robotics SDK allows to select the Intel-designed modules along with third-party component. It is compatible with a wide range of x86 hardware, LiDAR sensors, 3D cameras.
You might be even interested to run Robotics SDK on the real robot and that is why I found Mikrik open-source robot project could be a potential solution. It is a cheap, and easy to reproduce robot. Author also sells Ready-To-Run robots on Tindie, if necessary.
Mikrik Robot Source Project
First time I was amazed seeing that someone on published on Tindie a nice robot that supports Robotics SDK software called Mikrik. Project owner created a very detailed tutorial, link you can find on Mikrik product Tindie page.
I reproduced his setup 100%, and decided to bring my contribution to make the robot integrated more deeply into a Robotics SDK.
I've built new Mikrik robot version powered by a UP7000 single-board computer (SBC).
