Been doing an lunch kit analog glitcher with the Rev 1 Pcbs. It's going to have 2 glitchers inside of it. One a built in camera and the other for a vhs. The two knobs on the left bottom are for signal mixing. The right bottom is button glitches and switch glitches. The Inputs and outputs are on the top. It's going to be awesome once completed.
