ESP32-S3 - Touch TFT display board
first attempt at working with touch displays using FPC connectors, touch IC's and SD-Card.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
ESP32-S3
2.8" TFT resistive touch display
6x buttons
4x RGB Side-mount LEDs
PCB Chip Antenna
2x STEMMA QT/QWIIC connectors
LiPo charge circuit built in.
V1 attempted to use 8-bit parallel display connections however that took up too much GPIO.
V2 stepped back to SPI display interface to allow pins to connect an SD-Card.
Currently this project is taking a back seat to some other projects, however the goal is to keep thinking about how to improve this project.
