« Back to project details
OpenSCAD code
02/06/2017 at 19:04 • 0 commentsWant to make your own? Here's the code:
module arm(){ rotate([-45,0,0]){ cube([20,150,10]); translate([0,150,0]) cube([20,10,97]); translate([0,153,90]) rotate([45,0,0]) cube([20,10,30]); } } module vesa(){ translate([0,0,0]) cylinder(d=4.5, h=10); translate([100,0,0]) cylinder(d=4.5, h=10); translate([0,100,0]) cylinder(d=4.5, h=10); translate([100,100,0]) cylinder(d=4.5, h=10); } module mount(){ rotate([45,0,0]) union(){ arm(); translate([150,0,0]) arm(); translate([0,0,0]) rotate([-45,0,0]) difference(){ cube([150,120,5]); translate([35,10,0]) vesa(); } } } module brace(){ union(){ difference(){ cube([13,75,22], center=true); translate([0,0,1.2]) cube([10.3,102,20], center=true); translate([5,40,2.3]) cube([20,20,22], center=true); translate([5,40,2.3]) cube([20,20,22], center=true); translate([0,-55,0]) cube([30,30,30],center=true); } translate([15.2,29,0]) cube([20,2,22], center=true); } } mount(); rotate([0,0,-90]) translate([-150,110,11]) brace(); rotate([0,0,90]) translate([130,-90,11]) brace();
