Learning about transistors
Sometime before the Circuitpython fiasco, I watched the below video about transistors to understand the mystery on this board:
The main frames I want to point out are diagrams of a diode and NPN transistor:
Since matrix scanners only scan one row/column at a time, it's likely safe to assume that the designers of the WK-50 used transistors as alternatives to dual diodes (e.g. BAT54C).
I tried the KMK starter code and the keyboard matrix is configured as Row to Col.
Creating the layout in pog
Turns out pog can install/update KMK, which is nice.
Since I gave the board useful pinnames, it was barely an inconvenience to set up:
