Navigation
Prior Reading
Contents
The title tag system is explained here, and the table is updated when a change occurs. Notable logs have bold L# text.
Preface
[2024 - Aug 23 (last edit Sep 6)]
On paper, this keyboard looked and sounded great.
First, some context.
My Logitech G300S buttons were dying out, as well as the rubber sections, yet it had only been 8 or 9 months since I bought it. Perhaps I got a bad one, but this is the only mouse I have that is so particular to the type of surface it's used on. The reason I got it was because it was ambidextrous and programmable and seemed like a regular-mouse equivalent version of the Space Explorer which I tried (see #AirBerries and SpaceExplorer).
Since my (not so temporary) "temporary" keyboard probably passed its 3 year anniversary (essentially a full input-device term), I decided to start my search with keyboards first. Unlike the last time a few months prior when I was searching for "ergonomic" keyboards, this time, one with a trackball showed up:
That got me thinking and that lead me to the Weekin WK-50, a bat-shaped keyboard that seems to have the same amount of buttons as the AirBerries but had features I wanted if I was to get a custom keyboard again: USBC, non-split so it can rest on my lap, backlit keys and hot-swappable switches. It also had the nice-to-haves of a trackball and rotary encoder. I looked into switches and quickly determined that I'd probably like the Gateron Smoothie Silvers for their 1.2mm +/- 0.3 actuation distance, which is even lower than Kaith Choc low-profile switches (1.5mm +/- 0.5).
Receiving keyboards (wait, 'ds'?? plural?)
The thing is that the switches cost basically an entire wireless keyboard + mouse combo. Said combo even has custom, ergonomic-looking hexagonal keys! So I bought a Mofii Honey S. I'd gather more keyboard data that way.
I actually asked about hexagonally-aligned keyboards in the Keebin' with Kristina...
kelvinA
Conveniently, both a black and a cloudy grey ball arrived:
The black ball tracked mostly fine (and certainly better than the original grey ball) but the marble-like cloudy ball didn't at all. I correctly suspected this was because the balls were too close to the sensor, and found some m3 nuts to act as 2.3mm spacers. Now both balls would track but the cloudy ball would cause the mouse to jostle when stationary.
The balls track better, though I still feel that there's room for improvement so perhaps I need another 0.5mm of spacing.
The ball is mostly illuminated by the knob LED lights, so I'll keep that in mind when considering for a better knob (as the original one is too short and is opaque).
mkdxdx
That, my friend, is a lovely build. Thank you for posting a build log!
