Project homepage > haydenjames.io/download-arch-linux-raspberry-pi-wifi-access-point-setup
Are you looking into turning your Raspberry Pi into a Wireless router? I've created a tiny Arch Linux ARM + create_ap based setup, packaged into a downloadable image that may interest you. Once booted the access point will create SSID ArchWiPI via network address translation (NAT). UPDATE: Today I received my LB-Link long Range WiFi USB Antenna which replaced my Edimax EW-7811Un If you prefer mini dongles the best I've tested so far is TP-LINK TL-WN725N Wireless N Nano USB Adapter. These were manufactured for two very different purposes, I still love both. The LB-Link has more than double the range while the Edimax is about the length of a finger tip! But for the this project of turning the Raspberry Pi into a wireless router the LB-Link is a must have!
Hayden James
Brayden DeVito
Anton
Dmitry
I wonder how you are planning to fit this in uder 1kB, especially since the raspberry pi's BIOS would count...
