LED-Strip activated by a PIR-sensor or button, only turns on if the ambient is dark enough.
rgb_pir_light.pdfschematicx-download - 41.39 kB - 02/07/2017 at 17:39 |
I changed my 12V Supply to a higher quality one, now everything works as expected.
I think the problem was, in sleep mode the circuit draws so little current, that the supply can't hold a steady voltage.
The only small problem left is, at low brightness you can see the individual brightness levels.
In the future I may add 10/12? bit software-PWM to get smoother dimming of the LEDs.
I haven't fixed the power supply issue yet, but I finished the control box.
The box features a momentary button, a green LED (with resistor) and a toggle switch, which switches the 230V for the 12V supply.
Next week, when I am back in my apartment, I hopefully will figure out what causes the power supply issues.
Everything works as expected if I power the circuit via the ISP programmer (Arduino UNO) or my bench power supply.
But if I use the 3,3V regulator from the PIR-module, the circuit behaves strange. I also tried a L78L33AC regulator powered from the 12V rail, resulting in the same strange behaviour.
My circuit consumes less than 10mA, which both regulators should be capable of.
This is great. I was looking to do something like this using a few NeoPixels instead of individual RGB and using an ATTiny85 and some AA batteries to fit in with my Nest Protect smoke alarm pathway lighting. Just bright enough to illuminate a small area.
Will definitely have a crack at forking this. Cheers for the effort!
