3D file DIY Servo motor model
This is a project in the final year student's graduation thesis defense.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
In mechanical solutions, motors are typically required to actuate various components. In the increasingly democratized world of 3D printing, custom motors tailored to specific requirements can be created on the fly. However, there is currently no calculator that can relieve engineers of the tedious task of calculating every single property of a motor of this kind.
This project intends to provide a web-based parametric geometry dash motor calculator in addition to generating the necessary files for instant printing.
Every parameter must be left empty or have a realistic default value; the various default components, such as motor coil diameter and magnet characteristics, must be commercially available.
The calculator will first concentrate on brushless versions, synchronous (with magnets on the rotor) and asynchronous (without any magnets), as brushed motors can be very inconvenient to use.
