Current Progress: EverySwerve Build Completed!!
Team EverySwerve has completed the construction of the EverySwerve bot (See Figures 1 & 2) and will be demoing it for the first time this coming week. We are addressing some final electrical and software issues (both at about 90% completion) but are eager to show the work we’ve accomplished!
Future Plans: Validation, Validation, Validation!!!
In the coming weeks, Team EverySwerve will complete the validation of the EverySwerve bot through rigorous testing including tests like the 20 ft sprint, Slalom test (See Figure 3) & Obstacle Traversal test. These tests will verify many of our initial performance goals laid out last semester.
Progress Obstacles: Programming
Some of the EverySwerve validations require the use of programmed path tests. These programs must be written ahead of time and can cause poor validation results if done improperly. The team is aware of this and is prepared to address these issues as they arrive.
THowden-Capstone
