parametric eye-of-the-needle h-connectors
Cadquery-based parametric connector generator for fiber laser cutting
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
This project is for generating arrayed carriers of eye-of-the-needle connectors, for use in a discrete assembled geometry (4Hp).
cq_helpers.py contains helper functions for simplifying cadquery designs, mostly written with help from ChatGPT.
Source here: https://gitlab.com/sorslyd5-groups/inbox/ml_dice/-/tree/master/mcad/cq_dice?ref_type=heads
