Hackaday.io Hackaday.io
Sign up Log in
Supercon Badge Add-on for Oscilloscope Music
an add-on to display audio spectrum on the 2023 supercon badge
davedarkodavedarko
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
204 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
313
0
204
9
Team (1)
  • davedarkodavedarko
Join this project's team
  • https://github.com/davedarko/VectorScopeMusicAddon
hardware
completed project
Related lists
Dave's Badges + Simple Add-Ons
My Simple Add-Ons SAO and badges
This project was created on 09/02/2024 and last updated 2 years ago.
Description
Everybody loves oscilloscope music, but just plugging in the audio into the badge is not enough. The signal needed to be shifted and amplified into a voltage range of 0 to 3V.
Project Logs
Collapse
  • longer version
    davedarko • 09/02/2024 at 06:06 • 0 comments
    To fit Tinas case better, the design is now changed.
View project log
Log In/Sign up to comment
Sign up with Github
OR
There are more bats around than you think!
Project Owner Contributor
World's Smallest Bat Detector
spambakespambake
Easy tu build analog audio spectrum analyzer for 6 x EM800 TELEFUNKEN Magic Eye tubes
EM800 Magilyzer DIY kit
juergen-grauJuergen Grau
An Audio Peak Detector is an essential circuit in audio signal processing that identifies the highest amplitude or peak level of an incoming
Audio Peak Detector using LMV358
electronicsworkshopselectronicsworkshops
WAV player for Sipeed Longan Nano
RISC-V WAV Player
elehobicaElehobica
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Supercon Badge Add-on for Oscilloscope Music", please tell us the reason.
Send message
Remove Member
