Last update is again a major update with many changes.
09/21/2024 at 21:28 • 0 commentsSystem now runs mainly on RTC clock and when network, sync every 30 minutes the RTC with pool.
Offline, RTC is used and you can change this RTC time manually.
All internet applications: jokes, open-meteo and internet date/time are offline blocked.
Fm Radio Module start arduino setup the frequency that is stored on the Eeprom and puts Fm Radio Module in muted mode .
To get out of this muted mode, you just have to select the FM Radio in button Menu.
All games are now together in a vertical menu that is called up with Joystick Button.
Joystick Button is also used for selection in games menu and games.
Joystick Button is also used to rise flappy in play.
Other buttons (From left to right) :
Button 1: Fm Radio and humidity.
Button 2: UV index and air pressure.
Button 3: Air Quality and Open-Meteo.com .
Button 4: Internet date/time and manual RTC set .
.Selected button is also used in menu to perform menu selection.
MQ sensors menu is vertical, use joystick up/down to choose the right sensor that is plugged in.
Manual RTC setting buttons:
Button 4;Selection hour, minutes, seconds.
Button 1: Change value of hour, minutes or set the seconds to zero.
Button 2: Saving set time on RTC.
Button 3: Leave manual time settings without saving on RTC.
Fm Radio settings buttons :
Button 1: 0.1 Frequency lower.
Button 2: 1.0 frequency lower.
Button 3: 0.1 Frequency higher.
(The Frequincy in settings automatically jump from 88.0 to 108.0 and vice versa.)
Button 4: Put FM Radio Module in muted mode and goes out FM Radio Settings.
Joystick to the left + Joystick button: goes out FM Radio Settings and writes chosen Frequency on the Eeprom.
Joystick to the right + Joystick button: goes out FM Radio Settings.
All videos may have different images or animation than the latest updated version of Project !!!!!!!
09/21/2024 at 21:26 • 0 commentsVideo of Botje in Operation:
https://drive.google.com/file/d/1vl_shGyRmG-MU7OvcF3XYa6gA5LfyKxH/view
Video of FM Radio Module:
https://drive.google.com/file/d/1ATDQI8lEtzixks2tQREsxTE__SQdG3JZ/view
Video face R4 LED matrix :
https://drive.google.com/file/d/1yig8mSmTFw5lun-mWuM3_O87Oeiy0pP0/view
Video humidity and temperature :
https://drive.google.com/file/d/1aBAI_t65RNd9fRXFwBRJPth4M25G156c/view
Video UV index and pressure :
https://drive.google.com/file/d/1LpiWilkduq1KFA-Lj1tmkBKxas_EQVvB/view
Video MQ Sensors ( MQ Sensors are plug &;Play method. Do not forget necessary warming up time for MQ) and Open-Meteo.com :
https://drive.google.com/file/d/1h5M30COtwtHP1VNPKTO3ywfonnDyZlR2/view
Video Date - Time and Ttrivia Game :
https://drive.google.com/file/d/1Y4cCrgWzf2OU70jLsUPV0PXotMEPscGK/view
Video Snake and Flappy Game :
https://drive.google.com/file/d/1PLZREkEb9nalueP9ZfUnfH3-CecwNFvN/view
video matrix animation RTC-time= >12h<14h :
https://drive.google.com/file/d/1mEuzJQIFTs2Ansyr7R7T62vk_mo6Ip8x/view
video matrix animation RTC-time= >8h<12h & >14h<19h :
https://drive.google.com/file/d/1iJbZ4yMAHCe_uXH_kTfQ2giFJB446xlO/view
video matrix animation RTC-time= >19h<24h :
https://drive.google.com/file/d/1sjIwmtOUvf0dWBG2_UMgHp9MnlAZQeio/view
video matrix animation RTC-time= >24h<8h :
https://drive.google.com/file/d/1gqXVF857WY0UBUrHS5Wt1dgUXXaX3QZN/view
video matrix2 time (Less LED brightness between 7 pm and midnight, no time display between midnight and 8 am) :
https://drive.google.com/file/d/1IaMvuwuGBaxWwustG0aPGT0Op17hN8vE/view
---Final OLED image an animation videos (Update 27/08/2004)--
Online question, answer joke loop from v2.jokeeapi.dev on OLED (No joke 24pm/8am):
https://drive.google.com/file/d/12YEfJtUsX01AequNvzqSQ_ctmvFmd4Wf/view
Change and save time on RTC:
https://drive.google.com/file/d/15FNibRRzXYLu06zjr6aQZjPuPT-d0ZV6/view
Botje OLED Start Animation :
https://drive.google.com/file/d/1XCMvBs51Z8Zah7KnP9hYtEd8Kjl3-h75/view
Open-meteo animation and data :
https://drive.google.com/file/d/1MGj0vCfuj1C9yu4BGN_FDkc1XocyG4JV/view
Month calendar :
https://drive.google.com/file/d/1OpRrmqjVF3L5-lPZKZ5LFg-hPOmJUdI0/view
Trivia Coornrect Answered Animation :
https://drive.google.com/file/d/1S-H6jGUSuoCg1ZW_8W-NODkONzi5qmAh/view
Trivia Wrong answer image :
https://drive.google.com/file/d/1Rw-LrRvravq3aGwfc3EUOTz7s1jUKJ_n/view
Flappy game title and game over images :
https://drive.google.com/file/d/17JNX7AwiCFslq2LL4Fl_3MqLBRgx9J6a/view
Snake game title and game over images :
https://drive.google.com/file/d/1B48QOGezjHesQIc8wZLghP3DnTz1CdIK/view
All videos may have different images or animation in last update of Project !
09/15/2024 at 17:06 • 0 commentsVideo of Botje in Operation:
Month calendar :
Latest update : 15/09/2024
09/15/2024 at 16:59 • 0 commentsLast update is a major update with many changes.
Button 1: Temperature and humidity.
