Add a TPU module
A project log for aivision-H6
A Linux-based AI camera module that runs real-time deep-learning vision fully on-device for small robots and embedded projects.
blade-masterBlade Master 01/01/2025 at 21:430 Comments
## December 30, 2024 Year-End Update ##
The TPU module design for AI acceleration has been completed and is currently undergoing PCB testing. The module uses a Google coral TPU with a stamp hole interface compatible with the peripheral board and can be directly added to the peripheral board to work with the core board, becoming a powerful CPU+TPU edge AI inference machine. The neural network inference efficiency can reach 4TOPS (4 trillion operations per second), with a total board power consumption of only 6W. If needed, two TPU modules can be added to achieve 8TOPS inference speed. Here are two design diagrams:
TPU module 3D view
TPU module PCB raw design
