Hi all,
While we're waiting for our first batch of PCB's to come in, I wanted to start going over out software plan with you.
In our first update, Update #0, we talked about our goals which you can see below:
Goals:
- Allow for communication between two different boards
- Offload the communication between boards to the SAO
- Create an TV remote design to encapsulate the chosen parts
- Learn how to create a circuit for infrared components
- Learn how to use KiCAD
While these are overall goals for the project, we also have some specific software goals:
Software Goals:
- Leave the IR Protocol complexity to the SAO
- Simple i2c commands
- Ideally this is can be done with just three main commands: Get Data, Send Data, Change Configuration
- Make sure that programming the ATTiny85 is not overly complex
- Possible future features:
- Board ID's to ignore transmissions from unintended boards
- Retransmission of messages that were not correctly received
With this in mind, we want to use ATTinyCore as our go-to Arduino core. This is done for a couple reasons:
- Allows for most standard Arduino functions
- Ideally makes it easy for us and others to program
- Can use I2C Wire commands for easy I2C implementation
- Lots of documentation and example projects
- Continually updated and recently updated
We also want to use Arduino-IRremote as out IR Protocol library. This was done as:
- Support for many different IR Protocols
- Support for many ATTiny boards
- Small library version (necessary for small 8k memory on ATTiny85)
As we get closer to programming our ATTiny85, here's a YouTube video we're following to program it:
Alec Probst
