Using a solder paste dispensing needle, we first add solder paste to each component pad, one by one. We're using standard 37/63 solder paste here.
Next, we pick and place all the SMD components in their places on the PCB using an ESD tweezer.
With extreme caution, we lifted the complete circuit board and placed it on the SMT hotplate, which increases the PCB's temperature to the point at which the solder paste melts and all of the components are connected to their pads.
Next, we added the Through Hole USB Port in place and then soldered its pads from the bottom side of the circuit using a soldering iron.
The circuit is now completed.
2
RESULT
The result of the PCB Assembly process is this power module, which can provide a consistent output between 3 and 12 volts, depending on the source.
To Test this Board, we first connected it with our previous DIY Bench Power supply, which you can checkout from here-
We gave the power module 13V by connecting the bench power supply's alligator clips to the module's input terminals. We connected our multimeter to the output side, and the result showed 5.1V, indicating that the setup was successful. When several PD-using devices are connected, the output voltage will vary.
After that, we attached a LattePanda Version 1 to the power module's output via a USB cable, and the device powered up as anticipated.
3
CONCLUSION
The power module is operating as intended. The primary goal of this project was to create a tiny power module that resembled the MH-KC-24 power module that I had previously used in another project.
