PCBs arrived
09/25/2024 at 22:17 • 0 commentsThis will be fun to assemble...
There are two 'frames' around the actual PCB. One from the manufacturer and one custom by me to get castellated holes on all four corners the PCB needs to get cut an sanded down![]()
First Ideas
09/11/2024 at 16:43 • 0 comments- Small PCB with castellated Holes on the corners to fit inside of the four Pins of the Header
- Ultra tiny discrete RGB LED
- BGA Microcontroller ATtiny20-UU or similar
- 0402 passive are to big - 01005 does fit but not many
- Black header Plastic shroud does looks big and bulky in this context. Maybe there are Header with less - or just remove it
- Could be fun to assemble and manufacture this
Alex
