What is it?
Using the BLE caberQU is straightforward. Simply connect your USB-C cable to both sides of the device. The BLE caberQU applies a voltage across all the pins to test if they transmit the voltage to the opposite end. With 24 pins in a USB-C connector, plus an extra for the shield, the device uses LEDs to represent each pin's connectivity, giving you a visual indication of the cable's capabilities. But the BLE caberQU takes things a step further with its LCD and integrated Bluetooth connectivity. The device offers detailed information about the connected cable, including wire resistance, connected pins, USB Power Delivery (USB-PD) marker readout, and more.
Dinana
Paul Stoffregen
Stefan Wagner
