Specs
09/24/2024 at 15:33 • 0 comments![]()
The BLE cable tester by caberQU can test USB-C to USB-C cables for functionality, charging power, data speed, cable health and many more. It is the next step in the evolution of testing cables.
If you work with USB-C devices and want to keep them healthy by keeping your cables healthy, you might want to invest in the BLE caberQU cable tester.
Did you know that broken cables can harm your phone? And did you know that a lot of cables get damaged over time? But how can you know if your cable is broken? Get the BLE cable tester and test your USB-C to USB-C cables!
The BLE caberQU cable tester is super handy, quick and easy to read. Its digital display gives you the most important information on a glance: three dials show the maximum data transmission speed, the maximum power and the exact percentage of your cable health.
Plug it in with any USB-C cable. The screen will light up and show you how to plug in the cable you want to test. Now you can view data speed, charging speed and cable health all on just one glance.
With a few clicks on the buttons you can quickly navigate this device and display all its functions.
Screen 1 shows you an overview of your cable. Three dials show the maximum data transmission speed, the maximum power and the overall cable health.
Screen 2 goes into specifications. To be able to know if a certain use-case is supported, this column lists all cable features. USB1.1 to USB4, voltages from 5V to 48V and currents 0.5A to 5A as well as the complete connector pinout.
On screen 3 you can view the details. It shows raw information: each connected pin, the Vbus resistance and eMarker infos as well as the BLE caberQU hardware and software versions.
The BLE caberQU cable tester comes with a manual, a sturdy cardboard box and the product itself. It is fully assembled and can be used right away.
If you want your BLE caberQU to have a layer of extra protection, you can get the screen protector with it or for an easy travel option, you can add the hard shell case. If you want a well functioning USB-C cable to test out the product, charge your USB-C devices or transfer data quickly, we can also provide USB4 cables at 30% off.
We've been developing the BLE caberQU for over two years and managed to include the really useful feedback you guys gave us since 2021 on its predecessor – the C2C caberQU cable tester.
We have improved on many things, especially usability, a user friendly experience and all the additional information this product can show about your cable.
There is no other product like the BLE caberQU on the market right now, and as someone who constantly uses and frequently fixes cables, I felt the need to invent this little helper. It has helped me a ton and so I wanted to share it with you all – I think there might be a lot of people whose lives it would make easier.
