Changed my mind on the MOLLE/PALS idea for the ITA SAO BAG. Instead I've blocked out these 5x5 cm squares and will have the connectors spread out like this instead.
ITA bags are used for pins and plushies - comes from cringe / painful fandom and people putting too many stickers on cars
Screenshot 2024-10-13 at 02.55.43.pngPortable Network Graphics (PNG) - 81.30 kB - 10/13/2024 at 01:06 |
Screenshot 2024-10-13 at 02.55.55.pngPortable Network Graphics (PNG) - 104.25 kB - 10/13/2024 at 01:06 |
I designed them so I can use two boards for the bag, as that was cheaper. I'm using a Raspberry Pi Pico for I2C stuff and also the nice buck boost on board.
designed and ordered!
I decided to buy an ITA SAO bag and then sew the simple add-on inlay for it. I started like I would do welt pockets, but doing 44 of them simultaniously. You start with the two "good" sides facing each other and sew them together with the square opening you want to achieve. After sewing, I've cut the black cotton canvas material diagonally, so I could then cut a crossed hole right up to the corners and fold the flaps through the hole and basically turn it around. There are better and worse results when doing it 44 times, but this will probably hidden well enough with a lot of SAOs anyways.
I will probably cut up the wires and do the connectors next and then sew everything together.
controlled by the RP2040 PI COW it's basically a biggern supercon badge now :D
The title is all screwed up FYI. ""cringe" / "painful""
