This morning I finished porting all the examples from the raspberry pi pico to the pimoroni pico lipo for the rp-hal-boards. I did a pull request so we will see how that goes. I will also make a example reading the voltage and calculating the charge of the battery connected to the Pico LiPo. After that I will add the AE-RP2040 board, but first work a bit on my project.
I'm probably going to use github to manage the project code. I'll probably not have another coffee spill accident but just in case.
