OLED screen
A project log for ESP Audio Boards (v2) and Louder-ESP32
Spin off of ESP Audio Dock series of boards with refined and improved feature set
andriymalyshenkoandriy.malyshenko 05/14/2025 at 20:413 Comments
Small but colorful update. Starting May 2025, all boards will have an OLED screen solder-less connector. Originally, I added the OLED header on the back side of the PCB that would require careful and skillful soldering (It is quite nice when using squeezelite since you can get quite a lot with existing plugins and settings). Later on, I managed to find the right model of the screen and corresponding connector for a reasonable price, and decided to equip every board with the connector as standard.
At this moment, one can simply throw in a compatible OLED screen and use a small strap of double-sided adhesive to fix it mechanically. The final result is a nice and finished look
Vincèn wrote 03/14/2026 at 07:45 point
Where to find the documentation on wiring and model of screen supported ?
Thanks
andriy.malyshenko wrote 03/14/2026 at 16:54 point
Hey, it is here: https://github.com/sonocotta/esp32-audio-dock/?tab=readme-ov-file#oled-screen
Vincèn wrote 03/14/2026 at 16:54 point
Thanks :) missed it !
