The kits are done. Everything needed to complete it is in the bag. Including stranded wire from a CAT5 patch cable for the audio hookup part. That's the only wire I had around fine enough that made sense. Using larger wire is painful and unnecessary.
Now for a quick instructions update.
I am sad to report I was not able to complete the demo code beyond the audio portion. I still don't have the display code working. I am hoping to get that figured out enroute or sometime this weekend.
jeremy.geppert
