Blog #1 - Who, What, and Why
A project log for Paddle Shifters for UH FSAE
Capstone Team 26 – Eduard Amador, Eugenio Escamilla, Bryan Flores
eduardamador2021eduard.amador2021 09/26/2024 at 15:350 Comments
                               What is Formula Society of Automotive Engineers?
The University of Houston hosts the Cougar Racing team, a student-led racing team abiding the Formula Society of Automotive Engineers’ (FSAE) rules. The nature of a racing team is to continuously be innovating to get ahead of the competition, while “simple is better” has created a solid foundation, improvement of a team requires change. A motorcycle engine is the beating heart of the current Cougar Racing team’s powertrain system, as it is a common trend for those engines to be retro-fitted into FSAE race cars. This approach comes with the benefit that the transmission and engine come built-in together. FSAE teams thus have to design a pedal box that actuates the throttle cable and implement a shifting lever to cycle through the transmission’s gears. Cougar Racing has been using a shifting lever, which requires the driver to take one of their hands off the steering wheel and engage the clutch pedal every time they need to cycle through the gears. This process distracts drivers as they are diverting their focus from a race. If a system can take control of the shifting lever and clutch pedal, this allows the driver to focus on the course which leads to faster lap times.
                  Sample CAD of Paddle Shifters to be placed behind steering wheel
Our teams approach is to create a paddle shifting system that eliminates the need of a clutch and shifter lever, while keeping the driver’s hands on the steering wheel at all times and reducing the shifting time by 50%. High performance teams have adopted this system into their race cars and became an industry standard (for drivers to focus more on driving). A footprint constrain of 9″ x 7″ x 2″ is considered with the paddle shifters needing to sit behind the steering wheel. The system will be paired with an onboard computer that can read engine data, specifically, the motor rpm, current gear, & wheel speed. As the computer takes in data, it can rapidly change gears with a click on the paddle shifters. A set of pistons would engage the clutch lever and shifting lever which is controlled by the onboard computer through solenoids.
                             CAD of the Main Assembly of 2024-25 Competition Car
With the goal of creating paddle shifters for FSAE, we expect to work around premade hardware which adds difficulty in our design phase. Through in-person data gathering, we will be able to gather dimensions, constraints, and expect the adjustments to made in our early design stages. In the development of the paddle shifters, we will keep in mind how the mechanical components fit onto the pre-existing vehicle, but we must also must consider the environment the components. Considering the parts will be on a functioning car, they must be able to withstand external forces as the car accelerates and decelerates, as well as the heat generated by the engine. If our components are near the engine, an analysis must be done to identify the heat’s effect on our design. Additionally, because the paddle shifters are expected to give a significant competitive advantage, they must have the longevity to be reused in future FSAE cars and abide by the FSAE rule book.
Rich text editor
