SI-22G results.pdf
incoming test results of SI-22G GM tube... happily I had access to a Cobalt-60 source, but didn't even need to remove the lead lid to get crazy counts :)
Adobe Portable Document Format - 50.21 kB - 03/07/2017 at 21:19
Preview
base.stl
STL export of the light base, seen above in the pictures, and at the OnShape link...
Standard Tesselated Geometry - 2.36 MB - 03/06/2017 at 04:14
Download
diffuser_single_shop_drawing.pdf
"As-built" Solidworks pdf output for the acrylic LED diffuser, meant to be turned from 5/8" rod stock. Corners are broken and surface (including the inside of the LED pocket) is made matte using 400 grit wet/dry sandpaper, wetted with water-based cutting fluid. Prob more generally useful than the Solidworks SLDPRT file posted earlier.
Adobe Portable Document Format - 51.95 kB - 02/17/2017 at 20:17
Preview
diffuser_single_render.pdf
"As-built" Solidworks pdf rendering output for the acrylic LED diffuser. See drawing file for details.
Adobe Portable Document Format - 77.42 kB - 02/17/2017 at 20:06
Preview
