The aim of our project is to make an pneumatic robotic arm controlled by an IOT interface;
Knowing very little about pneumatic system and linear motion, it's an ambitious project for us.
We started making research on the major component that we'll need in order to make a pneumatic system :
- Pneumatic actuator
- Control Valve
- Air compressor
- Air Tank
Taking inspiration from other this is what we are aiming for (but using pneumatic instead) :
Since we want to control the pneumatic arm by an IOT interface, the control valve making the the actuator extend or retract will ne to be electrically controlled by a microcontroller, we settled on the use of an ESP32 with a webserver
