The cavity should be big enough for the electronics. I cut off a bit of the tail. first body print was pretty good. I had to make some adjustments for the servo cables.
I still need to:
- hollow out the head
- add every servo horn mounting
- find out if it actually moves and decide whether to hack the servos to continuos mode
- give credit to Benchoff in model
- salvage servos from somewhere ?Tote ?JohnnyIV until ordered ones arrive
davedarko
