By the way, Benchoff did a great job with the model, he also gives a printable version and stuff - but putting the parts into 123D Design was a pain, because the head and body parts have overlapping lines. I fixed that by "splitting" the mesh in meshmixer, removed one of two given objects (they were identical, but on the same spot - weird) and I might have pressed "autorepair" afterwards. Then I got something really low-poly, instead of the "make solid" buttons, that gave me objects with 200000 rectangles ... wuah.
Mad props to: #The Original Low-Poly Pokemon
davedarko
Kevin Cheng
Tanisha Agarwal
