I took no pictures, so here is a horrible fritzing "schematic"
03/05/2017 at 14:09 • 0 commentsThe walking puppy Sketch for the Arduino is in the file section, as is this picture and the latest, unprinted revision of 3D files. There is still no glue and the perfect version would have to have a 2 part head section and screws on the body. Take a bigger battery though, something like >160mAh?
Needs another revision or two
03/04/2017 at 02:06 • 7 comments -
This will be enough to work with
03/03/2017 at 18:46 • 0 comments -
dual sided power rail thing
03/03/2017 at 15:48 • 0 comments -
legs and tail have servo horn mountings
02/26/2017 at 20:03 • 0 commentsoff to the printer ... so many great projects in the contest and I want that oscilloscope - but I can probably forget about that already :D head is another topic, soonish, we're all on a deadline.
head hollowed out, eyes prepared for flux leds
02/16/2017 at 08:51 • 0 comments -
spend more time with the model
02/15/2017 at 11:15 • 0 commentsThe cavity should be big enough for the electronics. I cut off a bit of the tail. first body print was pretty good. I had to make some adjustments for the servo cables.
I still need to:
- hollow out the head
- add every servo horn mounting
- find out if it actually moves and decide whether to hack the servos to continuos mode
- give credit to Benchoff in model
- salvage servos from somewhere ?Tote ?JohnnyIV until ordered ones arrive
skeleton work
02/13/2017 at 21:55 • 0 commentsI've done some 3D sketching, servos are the classic SG90 servos, I still need to fit LEDs, an Arduino/ESP and a battery pack in there.
