Now a wider Range of SBCs are supported
12/20/2024 at 15:56 • 0 commentsHi, now other Zero format SBCs are possible. For example Radxa Zero 3W.
Files for Radxa Upgrade are now ready for download.
12/09/2024 at 13:29 • 0 comments -
Update Radxa zero 2 pro progress
12/03/2024 at 11:34 • 0 commentsIt seems I need to hotrod the radxa zero 2 pro sbc.
Converting USB Micro Female to USB-C male was a little challenge, but it works.
Upgrade the Portable PI
11/29/2024 at 09:56 • 0 commentsCurrently upgrading this Project for a Radxa Zero 2 Pro.
The height of the Case will increase by 3 mm to accommodate the Radxa. I have done a Battery Test and it seems not a Issue for Power consumption of the Radxa Port. Will do a Testprint This weekend.
Michael Mayer
