I started working on this project. The first version of the schematics is published on the github.
I've a little problem with the current sensing amplifier and therefore some modifications are still come: I want to make it a little bit more versatile therefore I plan to add INA193-INA195 also as an option. This ones are not able to work from 48V supply so in addition I'll add a zener based regulator as an option.
