I had to change my approach to this project many times as it changed phases. With investment casting, I have take the scientific approach and put the breaks on my humanity. To force myself to work only on planned tasks, not get distracted by randomly working on pieces of other tasks, and give each task the proper time it deserves I started keeping a daily log. Each day I write a mission statement and a list of tasks - I am not allowed to begin work before the plan for the day is written and it's set in stone until I leave.
Monday, February 20, 2017
Stories
- Get a perfect cast of the forearm clamp part – thin areas strengthened with sprues, perfect fill, no bubbles
- Get a perfect cast of both forearm shoulder parts
- Get a perfect cast of forearm cover parts
Tasks
2-part mold research- Clean up vacuum oven and vacuum chamber
- Continue 2-part mold research by cleaning up last night’s mold and pouring a second layer
temperature to avoid the mess?)
- Second shell layer (straight to secondary slurry, silica – fine)
- Install the new long blade on exacto knife
- Modify the forearm shoulder mold to remove thru holes and 1-3 test casts
- Modify forearm cover mold to add supports and 1-3 test casts
Tuesday, February 21, 2017
Themes (same as yesterday)
Tasks
2-part mold research- Inspect the 2nd part of the 2-part mold
- If successful, perform wax test
- If not successful, research why
- Inspect the wax injected into the two-part mold with the syringe
- Iterate on the mold by cutting pieces that cause thin areas and thus fracturing of the wax model
- Third shell layer (secondary slurry, silica sand – fine)
- Stretch goal: try measuring viscosity of the secondary slurry.
- Modify the forearm shoulder mold further to remove holes (to stubs)
- Modify the forearm cover mold to allow demolding thin edge on one end
- Fourth shell layer (secondary slurry, silica sand – coarse)
- Another iteration of modifying the forearm cover mold to allow demolding thin edge on one end
Tuesday, February 22, 2017
- Get a perfect cast of both forearm shoulder parts · Get a perfect cast of forearm cover parts
Tasks
- Inspect the wax injected into the two-part mold with the syringe · Iterate on the mold by cutting pieces that cause thin areas and thus fracturing of the wax model
Shell burnout research
Wax fracture research (stretch goal)
Val
