Featured video
11/03/2022 at 02:33 • 0 commentsToday Ligature Marks released a metal music video featuring this exoskeleton:
Some production shots:
Officially Done!
10/07/2022 at 04:48 • 0 commentsI took the exosuit to Wasteland Weekend, and only encountered minor inconveniences like bolts loosening and falling out. I would say the exoskeleton is now totally wearable and can be considered completed.
Almost done but paused for COVID
05/22/2020 at 23:13 • 0 commentsSome progress shots from working on exo gloves and reinforcing various parts of the exoskeleton. Most of this work was done during the winter, and relatively minor work is still left to do. The project is on hold until the work space opens.
Reinforcing and repair
01/20/2020 at 07:39 • 0 commentsRepairs after NW Wasteland Decompression party. Replaced plastic rod ends with steel ones from McMaster Carr, electrical wiring in the spine with bungee cords. Replacing finger connectors with elastic straps as well to make the suit appropriate for extended wear.
Completed, working out bugs
11/25/2019 at 16:20 • 0 commentsI got to wear the suit to Wasteland Weekend afterparty (did not make it on time for Weekend itself):
Assembly happening now!
09/25/2019 at 15:56 • 4 comments![]()
Painting
09/20/2019 at 06:36 • 0 commentsThis is the last week of painting, next I have assembly and tuning.
Done casting parts, onto finishing
08/09/2019 at 19:01 • 0 commentsI finished casting all the required parts mid-July and moving onto finishing & painting. So far it's been a month of finishing all the cast parts by using metal filler and modeling primer to sand over imperfections, as well as using a rotary tool to clean up tiny details. I expect much less effort to be required for machined parts. No idea how much time painting will actually take after all the parts are primed & polished.
In other news, I presented this project to high school students at the Pacific Northwest College of Arts:
3D Printing to Metal Casting: Making of Elysium Exoskeleton Prop
Casting chest & shin plates
07/01/2019 at 15:03 • 0 commentsThis weekend I made a second attempt at casting chest & shin plates. For the next one I will use thin sprues in addition to thick sprues to prevent parts of the model from breaking off with the sprues.
Wax parts before dipping to build shells around them:
First attempt:
Second attempt:
Both put together, before cleanup:
I will make another attempt at casting the chest plate to see if I can get it even cleaner, and then redo one of the shin plates before there wasn't 100% fill.
Exoskeleton chest plate 2-part mold
05/20/2019 at 22:21 • 0 commentsThe last mold required to finish this project! There are some optional parts left to make molds for that I might do if I have time left before the Wasteland Weekend.
Val
