First dips
07/22/2018 at 23:31 • 0 commentsThe first attempt at shell casting with the two chest plates has started. Sprued wax model:
First dip
Already developing cracks in the fist layer - most likely because the slurry needs more water
Second dip
Planning sprues
07/20/2018 at 19:58 • 0 commentsSprue planning for models to be cast using the shell casting process is more serious than with vacuum-assist casting, so I am performing at least two rounds of review with metal casting experts before proceeding:
https://github.com/01binary/sprue-planning/blob/master/chest-sprues.stl
https://github.com/01binary/sprue-planning/blob/master/hip-sprues.stl
Back to shell casting
07/20/2018 at 03:03 • 0 commentsThe last 7 parts cannot be cast using the jewelry process due to geometry that requires a very heavy custom flask and tons of investment. The weight of the finished piece makes it nearly impossible to manipulate fast enough to insert into a vacuum chamber and pour metal in 20 seconds, before shell-shock.
I am going back to shell casting after some advice from The Home Foundry forums, and I will post a video after the first failed experiments.
Investment casting in VR
06/18/2018 at 05:17 • 0 commentsAnother 360 video of trying out the new vacuum chamber:
Pouring molds in VR
05/29/2018 at 01:50 • 0 commentsI exported my first long 360 video with immersive effects, transitions and composited 3D renders:
Custom vacuum assist chamber and more molds
05/22/2018 at 19:54 • 0 commentsI've been working on a custom vacuum assist chamber for casting large parts:
I also got a 360 camera so now I can video blog & live stream the work on this project in VR. The editing should also be fun.
Lastly, I am continuing to make rubber molds for the remaining parts:
Starting on chest plates and more connectors
04/28/2018 at 17:39 • 0 commentsMore two-part molds for chest plates. Casting them in metal will require welding a custom steel flask because they are the biggest parts I will have to cast yet.
Batch of connectors and new mold
03/24/2018 at 20:38 • 0 commentsStarted a new two-part mold for shoulder connector heads:
A batch of four flasks with connectors & wrist clamps:
New vacuum setup with fixtures still working well:
Casting parts, started working on article
03/12/2018 at 05:42 • 0 commentsLast week I re-cast two parts with better detail and completed four other parts I already had molds for.
I also started working on casting some of the largest parts: hip and chest plates
Left chest plate two part mold (probably just the first draft, as I am still learning how to make these)
I also ordered a new batch of risers with inline ceramic filters.
Finally, I started working on an investment casting article. I want it to be the best reference for DIY investment casting on the Internet, so I'm taking time with reviews, edits, and graphics. Seeking feedback from anyone here:
Finishing first parts
02/05/2018 at 04:19 • 0 commentsI've achieved the highest quality casting results possible with my setup, so I am learning how to use a FlexShaft this weekend to finish parts after cutting them off the sprues:
Also casting wax parts to begin another metal casting batch:
