2025 updates
A project log for HMC-20
The HMC-20 Human Machine Controller creates a versatile and fully customizable Human Machine Interface.
sam-lefebvreSam Lefebvre 01/23/2025 at 15:590 Comments
Some updates are currently available:
- Integration with json. You can now add and extract a layout in json format from the SD card.
- Menu over a virtal serial com port with USB-C cable where you can load and activate multiple layouts (images + json), clear the memory, request device info, set the clock and perform a secure firmware update.
- Integration with mcuboot to upload a signed and encrypted image.
- Setup of 2 demo applications (fogger and home automation) that are available on a SD card. They show the possibilities to interact with digital IO and an external Python script over the command interface.
- Devices can now be ordered on Robotshop and Tindie.
- Update of documentation and datasheet.
