Let's go back to the start
A project log for Experiences with ESPhome
Setting up some ESPhome-devices
mabe42MaBe42 02/08/2025 at 19:570 Comments
The more I used ESPhome, the more confused I got. So I decided to start over again and provide some examples for things I had understood or which at least I thought I had understood.
I took a Wemos D1 mini board and generated a new yaml to which I just added a wifi sensor, as it's always good to know the wifi strength when testing.
esphome:
esp8266:
  board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
  password: ""
ota:
  - platform: esphome
    password: ""
wifi:
  ssid: !secret wifi_ssid
  password: !secret wifi_password
  # Enable fallback hotspot (captive portal) in case wifi connection fails
  ap:
    ssid: "Eh-Test Fallback Hotspot"
    password: "password"
captive_portal:
sensor:
  - platform: wifi_signal
    name: "WiFi Signal Sensor"
    update_interval: 10s
 As for the wifi credentials, it's necessary to create a secrets.yaml in the same directory as the above yaml file and provide the credentials there:
wifi_ssid: "your_ssid"
wifi_password: "your_secret_password"
In home assistant (HA) this can then be seen as
(Settings -> Devices & Services -> ESPHome -> Devices)
